HI again, thanks Old-Biscuit for your comments, I really didn't know the procedure for weighing. This is the third FW my wife had her heart set on, the other ones, just by checking the tags, I knew were too heavy!!! So it ended up being a " kin we, kin we, Pleeeeesssseee", So now I have to figure out if I can safely pull it!!I think you have the info you need to tell me where I sit? If you need more let me know. I did have a small level with me, on the scale, the truck rails were a little high back to front and the FW was a little high front to back, it looked really good over-all. Also there was some wt. in the FW, two full 30 lb. propane tanks, two batteries, same water in all tanks (why, I don't know).Knowing that, makes it more confusing!! Anyway thanks again, Dan
