Cummins12V98
Feb 27, 2017Explorer III
I probably missed it but is the truck an automatic? If so it is not a flywheel that was damaged. They are called a "fex plate". Also if increasing the engines output or upgrading the trans the FlexPlate should be an upgraded model able to handle the torque. If they are installing an OE unit you may have the same issues again. I would have one overnighted from BD.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
