- WizbangdoodleExplorerParked it for awhile. TV is broke down.
- pipers_familyExplorerChecked out the generator under load- and looked for our next camping spot. Also checked out our new steps with landing (for pup and us) Decluttered, and installed garage storage hanger.
- RambinoExplorer
N-Trouble wrote:
Rambino wrote:
Installed 2 6v house batteries and a 12v generator starter battery with battery separator. They just fit in the battery tray.
Installed propane quick disconnect fitting for camp chef.
Adapted garden hose fitting to fresh water tank drain. (We are in drought strapped California so need to use left over water efficiently :D)
Replaced suspension equalizers with Dexter E-Z Flex.
Installed landing gear power kill switch.
How was the EZ Flex install and have you had a chance to tow with it? Does it affect ride height at all?
I put a E-Z flex with wet bolts on a triple axle toyhauler we had. 4 equalizers and every plastic bushing in the springs replaced with brass. two people took about 4 hours.
The 28sag already has wet bolts so replacing 2 equalizers should take less than an hour. It does make a difference as stated in another post. Well worth the price (less than $120) and pretty easy for the mechanically inclined. The equalizers are a direct replacement for the originals. No significant change in height. Normal towing seems the same. It is when you hit the bumps and ruts and RR tracks when they shine! - fj12ryderExplorer IIII put the EZ Flex w/wet bolt kit on my triple axle and it is the best money you can spend on your trailer, pure and simple. The change in the towing and ride is night and day. It may have raised my overall height 1/2 inch, maybe.
Do it, you'll be glad you did.
My opinion, even though you didn't ask for it. :) - N-TroubleExplorer
How was the EZ Flex install and have you had a chance to tow with it? Does it affect ride height at all? - RambinoExplorerInstalled 2 6v house batteries and a 12v generator starter battery with battery separator. They just fit in the battery tray.
Installed landing gear power kill switch. - 1L243Explorer IIToday I backed it up to the Teton Mountain Range in Wyoming..
- N-TroubleExplorerRecently performed the following.
1) 300W GoPower Inverter Install
2) Mounted 2nd TV in front bedroom. Used a Mor/ryde TV1-025H locking mount
3) Installed Steadfast stabilizer. These work great! Highly recommend.
- LKHAExplorerHome from fist outing. Two weeks no major issues
- VulcanmarsExplorerTake the cover off for a weekend trip if it ever stops raining. Cover is too wet/heavy at this time.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
