ol_Bombero-JC
Sep 07, 2013Explorer
TucsonJim wrote:
I guess that it all depends on what you mean by a good weight. Here are some things to consider:
1. GVWR of the FW vs. Dry weight.
2. Hitch weight that your truck can handle so you still have enough capacity for cargo and people.
3. GCVWR - This is the gross combined vehicle weight rating. In other words, you don't want to exceed this total number with your tow vehicle, FW, all cargo, liquids (propane, gas or diesel, water, etc.), and people.
4. Fuel Economy - Typically, the heavier the FW, the lower your mileage. However, aerodynamics comes into play here also.
5. Axle Weight Ratings - You don't want to exceed the maximum rating for any of the axles in the TV and FW.
Typically, the aluminum frame FWs are lighter than wood frame construction. And yes, you're correct that many of the newer models are using newer materials to make an equivalent FW lighter than it would have been 10-15 years ago.
Good info, and -
Some of the older 5ths were better quality (throughout) than the 'newer' models. (even 5 years ago).
Some have higher quality cabinetry, etc.
Unfortunately, Some are now "orphans" - mfgr went out of business, but still an excellent choice for a used 5th. Ex: Alpenlite.
BTW - you can save a bundle of money by finding a quality used 5th..:W
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
