mapguy
Jun 29, 2017Explorer
Learjet wrote:
Doesn't the equalizer, if you have axles with springs, keep even weight on both axles...hence the name equalizer?
Assuming close to level.
Nope. Common misconception of the equalizer function. Equalizer is there to allow the axles to articulate individually while traveling. Suspension travel is limited any time the nose is high or low from the frame level position.
Easy to see the suspension limiting action when trailer is disconnected by raising/lowering front jacks while viewing what happens at the equalizer.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
