- 3oaksExplorer
I run at max cold pressure as stated on the sidewall..
I do the same. - Mandalay_ParrExplorerI run mine according to the weight load chart by the tire Mfgr.
- TxsurferExplorerOk good info thx
- TexasChapsExplorer
Txsurfer wrote:
I have LR D tires on my TH. GVRW is 8000. 4200 dry and i don't haul but maybe 1000 lbs all in. For relatively light loads such as this what PSI do you reccommend. 65 is max and I'm currently running 50-55 PSI. About to put 2000+ miles on it next week.
I run at max cold pressure as stated on the sidewall.. - ScottGNomadRun at max.
- naytherExplorerI'd run at max. PSI. Tires run cooler with more air, downside is a bit stiffer ride and possibly more wear in center of tread but ride is not a priority and you'll not wear out the tires before they "age" out.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
