donn0128
Nov 08, 2016Explorer II
For many years all I did was blow out. I learned early on that higher is not better. I found that 15-20 PSI was ideal. Any conpressor capable of that will work. I use my 135PSI pancake compressor andmit does just fine. Since adding a washer I now first blow out, then pump antifreeze so the washer is protected.
About Fifth Wheel Group
