lc0338
Nov 08, 2016Explorer
Don't need more than 45 psi or you could damage your plumbing. I have an adapter that looks just like a tire valve stem. I connect the tire valve to my fresh water in line and set my pancake compressor regulator to 45 psi. I air up the plumbing then go inside and open one water source at a time. The blast of 45 psi coming out does a pretty good job of blowing out settled water. I do this multiple times on each water source. pressurize the plumbing and then release one valve at a time.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
