glodal134
Nov 11, 2016Explorer
My DW and I have owned 10 RVs in the last 50 years, There is one thing that I have learned for certain, There is no such thing as over kill when it comes to preventing water lines freezing. I learned this the hard way many years ago, I waited too long to winterize a 5th wheel and later I had to remove the bath room wall to make repairs.
I use a small compressor and put 40 # of air in the lines then I go from out let to outlet and release all the moisture out of thr system, then I pump RV antifreeze thru all the lines. And of course I drain the water heater. The pink stuff is cheap and the process only takes 30 min.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
