enblethen
Sep 02, 2016Nomad
As soon as you plug the rig in, the converter will try to charge the battery at it's given rate.
This could happen the same time as you try to use the microwave.
A good 2000 watt genset should handle both.
A 2000 watt may or may not handle the a/c unit if you are thinking of that.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
