Cummins12V98
Mar 20, 2020Explorer III
JIMNLIN wrote:Cummins12V98 wrote:
So If I were a resident of BC with my 14k DRW that has a SAE rated RAWR of 9,750# and I loaded it to that and didn't add a single pound to my front axle weight of 5,250# bringing my actual loaded weight to 15k what would happen???
Nothing according to IBC motor vehicle act if you had 15k GVWR registration;
Maximum gross weight for axles
**7.16 (1) A person must not, without an overload permit, drive or operate on a highway a vehicle loaded or configured so that
(a) the gross weight on an axle exceeds the manufacturer's rated capacity for that axle or for the brake or suspension system with which the axle is equipped, ...**
And of course we know in BC you may register your truck at a GVWR which can be the sum of the vehicle mfg axle ratings or the vehicle mfg GVWR.
Most rv folks are assuming BC GVWR registration has to be the door sticker GVWR number.
Thanks!
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
