Curly2001 wrote:
The newer truck is taller than the old one. Still looking at ways to remedy that either by correct track or trying adjust with the pin box. I am about 2 inches higher in the front than the back but if I leave it hooked up I am about 2/3 or so of a bubble high. I realize I can also unhitch which I may do if I don't get it level. I just didn't know if boards were the answer or if the plastic blocks would work as well.
Curly
What type of 'leveling' system do you have.....
4 or 6 point electric/hydraulic leveling system
OR
electric/hand crank stabilizer jacks at rear >>
Electric/hand crank "STABILIZERS" are just that 'stabilizers' ...NOT to be used for LIFTING
Rear of 5vr is LOW and stabilizers are not what you want to use to 'LEVEL' the 5vr
With Nose High condition......unhitch and level by lowering the front jacks and using rear jacks to stabilize.
If you have a 'leveling system'......???????
Think you would still need to unhitch
