MikeRP
Oct 03, 2021Explorer
Cummins12V98 wrote:MikeRP wrote:
My 2020 Longhorn Ram 3500 w Crew Cab and long bed has a payload of 4156 lbs. My Cedar Creek weighs about 14,500 lb loaded which translates to 2900 lbs on the pin and that math works. So I have a 46 gallon aux tank that weighs 350 lbs full and a small capacity tool box.
So loaded ready to go i probably only about 3-400 lbs from max. So if you are buying a new truck at the very minimum get. 3500 payload even on a 350 or 3500 series truck w single rear wheel gets eaten up fast! And it costs so little extra to get a 3500 versus 2500 it’s a no brainer.
Have you ever weighed your Truck and RV? 2,900 pin on 14,500# is exactly 20%. I am willing to bet your numbers in reality are different.
I think they would be different but I don’t have the washer dryer in the front nor the Onan generator. So actually I think it’s been running like 19% but I will check it again next spring before I leave. Plus my wife and I have been through a rigorous process of not having stuff on board the truck or the camper that we don’t need and don’t use. We have shed a lot of weight. I had stuff in there from two RV’s ago.
Thanks
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
