Why waste all that money and possibly end up with another junk axle? They are all made the same way unless you have a Mor-Ryde IS which is adjustable. My axles were both tracking to the left. If new axles would have been installed they would have done the same thing due to the way they were attached to the frame. The spring hangers were off. For around $150.00 which is way less than replacing an axle, you can have it aligned and it's done..end of story. They will also set the tow and camber. No guaranty a new axle will be perfect. By the way, a new axle comes pre-bent in the center to set the camber on it. Don't get suckered in to buying a new axle thinking it will fix anything.
Absolutely right.
