93mastercraft
Jul 02, 2013Explorer
Wheel bearing Grease
How often do you check your wheel bearings? This weekend I had to replace one of my tires, so I decided to check the wheel bearings. Mine have the hub caps where the entire rim and tire have to be removed to access the grease fittings.
I was surprised at how much grease I had to pump in. On a triple axle I went through two tubes of grease. I pumped enough grease into each until I saw the grease come out the front. Do manufactures not fill these things up w/grease?
