- joelcExplorer IIILevel entire unit/then slides. If the unit is not level you might put a strain on the slides.
- 2oldmanExplorer IIIt's hard to imagine why anyone would need slides out first, unless of course the obvious being you think slides put the coach off level.
- Coach-manExplorerIMHO, it just makes good sense to level first. Otherwise, as stated it could put undue stress on the slide out, and/or the mechanism!
- drfifeExplorerI have hydraulic jacks front and rear.
1) Level front to back with front jacks.
2) Extend slides
3) Extend rear jacks
4) Level side to side
When time to break camp:
1) Retract rear jacks
2) Retract slides
3) Adjust front jacks for hitch
This sequence for set up and take down results in the least torque and stress on my trailer frame.
This applies only to hydraulic systems with or without auto leveling. - sdianel_-acct_cExplorerWe level twice. Before and after we put the slides out. HWH in Iowa said level first.
- old_guyExplorermy manual says level first then slides
- HalmfamilyExplorerLevel first. On ours, I have opposing slides and would have to climb under them to add 2x to level side to side if I extended them first. That would be too much of a pain. Front to back no problems.
- TerryallanExplorer III level, and hookup everything out side before I put out the slide.
- korbeExplorerThe slide goes out after all leveling and disconnecting has occurred. More difficult to crawl under the slide to mess with the wheels. We do however, when checking for level side to side, leave the slide side a hair higher prior to extending. Better than a hair lower for that side.
- NJRVerExplorer
X2
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
