AceiExplorerOct 28, 2014Which pickup would you use to pull 25ft 13k FW?If you had a 5th wheel with GVWR of around 13k, what class pickup truck would you use to pull it? 1/2t truck won't do it, this is a no brainer. How about 3/4t truck? I think the pin weight will ...Show More
spud1957ExplorerOct 29, 2014A properly geared 1 ton gasser would do it but if you can afford the extra $8-$9000 (new) then go for the diesel.
