Winged_One
Oct 30, 2014Explorer
Acei wrote:
If you had a 5th wheel with GVWR of around 13k, what class pickup truck would you use to pull it?
1/2t truck won't do it, this is a no brainer.
How about 3/4t truck? I think the pin weight will be challenged. I guess the safe choice is a 1t SRW truck? I think a dually is an overkill in this setup.
How about Diesel vs Gas for this FW?
A SRW 350, as long as you don't over load the truck with people and things, should be adequate (check ratings on the door to be sure).
If the gas is adequate for the weight, go that way, if not, diesel.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
