Acei's avatar
Acei
Which pickup would you use to pull 25ft 13k FW?
If you had a 5th wheel with GVWR of around 13k, what class pickup truck would you use to pull it?
1/2t truck won't do it, this is a no brainer.
How about 3/4t truck? I think the pin weight will be challenged. I guess the safe choice is a 1t SRW truck? I think a dually is an overkill in this setup.
How about Diesel vs Gas for this FW?
  • That would be very heavy for a 25 footer. Have you weighed it?
  • Having pulled a 13K FW with both gas and diesel TVs, I would throw my vote towards the 350/3500 diesel SRW for this choice. The torque and HP from the diesel nice to have.
  • Assuming a 20% pin weight, my F250 would be over its GVWR but under its RAWR. But I agree, a one ton SRW would be a better choice.
    I will always say skip the 3/4 and go minimum 350/3500 SRW with a fifth wheel.
    But then 25' 13k seems out of balance. 8200 GVWR F150 should pull most 25' fifth wheels just fine.
    I would try to go gas as diesel seems too complex (expensive) lately.
  • Whats the dry weight of the 5th. And how much do you plan to put in it. GVW is meaningless. You could have a 9000lb 5th with 4000lbs of CCC. You need to find out the loaded weight and then figure 20% for pin. Work that number against you trucks payload or RAWR.
  • My 5er has a 13,500 lb gross rating. It's right at the towing weight limit for my dually gasser. It would be over if I had the standard 3.73 gears. Pin weight is no problem even with a 80 gal aux tank. It pull great.
  • Our Chevy 3500HD is a diesel DRW.
    Our 5r is ~13k gross and 33', but she has a heavy pin weight of ~25%>.
    Better to have too much truck than not enough.
  • I have a Diesel 3500 SRW and my 5vr is 34' 14K + GVWR
    I am right at RAWR/Tires cause I run heavy (13,830#)
    Absolutely smooth matched set up. 70,000 miles of towing it FT
  • Diesel dulley. You have to worry about pushing rated limits and for future upgrade trailer.
