Me_Again
Aug 26, 2014Explorer III
Wadcutter wrote:
IL does not allow 3 vehicles in tow except in certain agricultural uses. The only legal multi-vehicle tow is a 5th wheel towing a boat, jet ski, ATV, or motorcycle. Max length is 60'.
5 ILCS 5/15-107
(5) Recreational vehicles consisting of 3 vehicles, provided the following:
(A) The total overall dimension does not exceed 60 feet. (B) The towing vehicle is a properly registered vehicle capable of towing another vehicle using a fifth-wheel type assembly. (C) The second vehicle in the combination of vehicles is a recreational vehicle that is towed by a fifth-wheel assembly. This vehicle must be properly registered and must be equipped with brakes, regardless of weight.
(D) The third vehicle must be the lightest of the 3 vehicles and be a trailer or semitrailer designed or used for transporting a boat, all-terrain vehicle, personal watercraft, or motorcycle.
(E) The towed vehicles may be only for the use of the operator of the towing vehicle.
(F) All vehicles must be properly equipped with operating brakes and safety equipment required by this Code, except the additional brake requirement in subdivision (C) of this subparagraph (5).
So do you think the Anderson hitch which connects via a ball in place on the king pin is a "fifth-wheel type assembly" per the code above? Would an Anderson hitch require safety chains in your state? Chris
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 29, 2024
