- Jim-LindaExplorer IIIf one uses a sufficient TV, pin weight doesn't matter.
Jim - DSteiner51Explorer
rhagfo wrote:
REWahoo wrote:
motorcycle jack wrote:
The placement of the items inside has very little to do with the pin weight. It is where the balance point versus the axle placement that effects it most. If you have a problem with understanding that, let me give you an example. Lets say the given 5th wheel has a total weight of 10K and the pin weight is 2K (20% of total weight). Now add 1K to the rear of the unit. Does that mean the pin weight is now 1K? Since you added it behind the axle (which is not the balance point). No. The total weight is 11K (10 + 1) and the pin weight is now 20% x 11K or 2200 lbs. Sorry, just the nature of the design.
An engineer will be along shortly to point out the inaccuracies in the above post. :)
Some pretty fuzzy math in there, sorry Jack, if placed at the rear of the unit it will lighten the pin, no not by 1,000#, but unless the wheels are at the rear of the five by a good percentage of the 1,000#.
You are very kind... it isn't fuzzy math, it is just flat WRONG!
I designed numerous trailers and depending on what it was being used for determined where the axles were placed. My rear kitchen has no more or less percentage then any other 5th wheel/gooseneck. Food in the fridge and pantry doesn't add up to much therefore makes little difference on pin weight. My fresh water is over the axles and black/gray tanks just ahead of the axles. Depending on just how long the wheelbase of the trailer is the junk in the front storage compartment would make a difference of approx 1/2 the weight of the junk. - FlatBrokeExplorer IISort of along the same topic but I never could figure out why some Truck camper makers put the propane bottles back of the rear bumper.
- rhagfoExplorer III
Some pretty fuzzy math in there, sorry Jack, if placed at the rear of the unit it will lighten the pin, no not by 1,000#, but unless the wheels are at the rear of the five by a good percentage of the 1,000#. - korbeExplorerMy fresh water tank is to the rear of the axles.
- Water-BugExplorer II
He rides a bike. Cut him a little slack. :) - REWahooExplorer
An engineer will be along shortly to point out the inaccuracies in the above post. :) - notevenExplorer III2 motorcycles standing quietly in their garage stalls works just right :)
- motorcycle_jackExplorer IIThe placement of the items inside has very little to do with the pin weight. It is where the balance point versus the axle placement that effects it most. If you have a problem with understanding that, let me give you an example. Lets say the given 5th wheel has a total weight of 10K and the pin weight is 2K (20% of total weight). Now add 1K to the rear of the unit. Does that mean the pin weight is now 1K? Since you added it behind the axle (which is not the balance point). No. The total weight is 11K (10 + 1) and the pin weight is now 20% x 11K or 2200 lbs. Sorry, just the nature of the design.
rjsurfer wrote:
Get a rear kitchen model....
Ron W.
Has absolutely nothing to do with pin weight. Mine is rear kitchen. The engineers moving the position of the axles can and does make a big difference.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
