Cummins12V98
Jul 12, 2017Explorer III
Gib3633 wrote:
Cummins12v98:
It would be interesting to see a picture how that Ram is sitting after the 3 inch riser was added to the Mobile Suite.
Mor/ride measured my Mobile suite and added a 2 inch riser and made a huge difference in the ride. I wish they would have taken another moment and I'm sure it would have gotten the 3 inch like your trailer and still 13ft 6 in
With the 3" riser added I am at 13' 5".
Here is my scale weight from the WA State Dot scales.The individual RV axle weights don't exactly add up to the combined weight because I weighed each axle separately at the edge of the pad and is slightly less accurate. Point is you can see my axle weights are VERY close now with the 3" risers added. Prior the rear axle weighed 1,400# more than the front. Was towing MC trailer.
Truck sits no different since I have the Factory Rear Air ride that maintains the set height up to and possibly beyond the 9,750# rear axle rating.
First pic is with risers, second is without. First pic the blocks are there for stability when not unhooking overnight. I just put enough pressure to stabilize.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
