mekkerl
Jul 12, 2017Explorer
laknox wrote:mekkerl wrote:
PhoneDude -- where did you get your kit?
And, did you do the work yourself? Was it pretty straight forward?
I assume the kit comes with longer u-bolts and everything needed?
I'm sitting about two inches high...and only have about 2-inches of bed rail clearance.
2" bed clearance!? How do you even tow down the road without rubbing? :h If true, you =really= need to raise the FW; likely the only way to get that kind of lift is will a full-on subframe. 4" =minimum= to be sure.
Lyle
I'm probably about 4" from actual truck rails...but my bed cover has a rise of about an inch or so. I measure from that. So probably about 2.5-3.5 inches usually when towing overall. I haven't had any issue towing roads etc...only twice when backing into sites that were either much higher or lower than the road. Which then I had to unhook and raise the hitch. Not fun to do that, hence why I want to raise the camper a few inches.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
