Coach-man wrote:
donn0128 wrote:
3500, you will never regret havine enough capacity.
Yes, until you pull into a parking garage, while your out exploring on your travels!
2500 and 3500 SRW are the same size.
Coach-man wrote:
Also, keep in mind many 3/4 ton vehicles are the exact same vehicle as their 1 ton SRW counterparts! Difference, in some states the 1 ton gets extra taxes and/or license requirements! Do the research, check your anticipated pin weights, check the ratings of the tires, and wheels. If RAM, is a "Heavy Duty" with the same engine, transmission and rear end as the 2500? Make an intelligent informed decision!
The 3/4 and 1 ton Rams are NOT the "exact same vehicle" as I've detailed in this thread (to the chagrin of some).
Rusty
