SailorGuy's avatar
SailorGuy
Enough truck?
New TT user. I'm considering purchasing a Lance 2185 TT (https://www.lancecamper.com/travel-trailers/2185/specs/) or similar size and weight TT. Before I buy (used) I plan to rent one next month using my current truck to pull the trailer to try this trailer out. I have a 2008 Ford F150 2x4 Supercab with 4.6L V8, 145" WB, tow package and canopy.
According to the door jam sticker this truck has a GVWR of 6700# and a payload capacity of 1568#. The Lance has a weight of 4565#, payload of 1435 for GVWR of 6000#. The hitch weight is 755#.
It will be just my wife and I in the truck for this trip. If I add up our weight (200# each) + 200# topper + 745# hitch weight I'm at 1345# which is within the 1568# max payload. Is this too close? If I use the 15% of the 6000 TT GVWR as the hitch weight I get 900# plus the weight of us and the topper (600#) which is 1400# just barely below the 1568# payload. Too close? The truck rear GAWR is 3800#.
If I decide to buy the TT after the week trial, I plan to replace my current F150 truck with a newer (2015-2017) F150 SuperCrew 4x4 145" WB truck with greater max towing rating. I was thinking of the 3.5L Turbo V6 engine (10,700# towing) or should I find a truck with the 5.0L V8?
Am I ok to tow the Lance with my current truck for the week trip? Advice on a used F150 truck?
Thanks
