TxGearhead wrote:
hbillsmith wrote:
Make sure your wheels or OK to run 110psi. That size as an ST like the Maxxis 8008 version is only 80psi. The Sailuns need 110psi for 75mph and higher load limits.
Supposedly Sailun is Ok with running them at 80PSI as long as they are within the load range for that pressure.
There's an email quote from a Sailun rep on keystonerv.org about 6-10 weeks ago.
Correct. We replaced WestLake load range Es with Sailun load range Gs. The trailer (all types of trailers) dealer/expert than mounted the tires asked how much weight I was carrying on each wheel and told me to run the Sailuns at 100 PSI rather than 110. Many tire manufacturers publish load and inflation charts for this purpose. Prior to purchasing the tires, I confirmed that the wheels were rated for 150 PSI.
Rob
