stro1965
Oct 28, 2015Explorer
Winterization problem
My Fuzion has a winterizing input for the anti-freeze. I tried to use it this afternoon but couldn't get it to work. I drained the low points, drained and bypassed the water heater, and flipped the switch to "winterize". I then dumped a couple of gallons of anti freeze into a bucket and hooked up a short (6') hose. The water pump absolutely would not pull the anti freeze into the system. The only way I could draw anti freeze was by raising the hose up and pouring directly into it (I have an outside shower thing that allowed me to try it while I held up the hose).
I ended up using a small external submersible pump and hooked up my hose to the city water connection in order to get the pink stuff throughout the system.
Any ideas why the on board water pump wouldn't pull the anti freeze? Works just fine to pull water from the fresh tank. I wonder if the standard size garden hose is too big compared to the smaller internal lines?
I'll take it in (under warranty) but I'm tired of finding things on this camper that don't work. Last Keystone product I will ever buy.
