Grady23's avatar
Grady23
Winterizing --- Antifreeze or blow'em out??
I have a 2010 Cougar 318 and in the past have always used the R/V Antifreeze in the unit. I have a compressor which can be dialed back for a reduced pressure. Do I run the risk of leaving small pockets of water in the lines or does this method do the job? I plan do drain everything before I use the air.
