PenMan
Oct 07, 2013Explorer
stro1965 wrote:
Ok, I was able to do the city water connection by removing the screen, relieving the pressure by opening the outside shower valve, and pushing in on the detent. Pink stuff came out so I assume that's good. I don't have a washing machine or an ice maker, so maybe the only thing I haven't covered is the black tank flush. I know I didn't do it last year either. How important is it?
Just use a compressor to blow out the black tank flush. You don't need pink stuff in it. I get to do the winterize chore this weekend. I have never used the pink stuff before but did have a problem last year with just blowing everything out with air. I had not considered how to put pink stuff in the city water connection. I think I will just blow it out with air and then change the valve positions to take in the pink stuff with the pump.
One more item. I take the 9 volt batteries out of the detectors and put in new ones next spring.
About Fifth Wheel Group
