ToddD's avatar
ToddD
Wireless Reverse Camera Questions
Looking at a 2018 Jayco 43' 5er. Can either come with camera prep or a Furrion wireless unit. Prep location is center top of rear wall.
Reports from Jayco owners on factory camera are mixed, reporting delayed video when in motion and low res display.
With a typical factory prep package in place, what aftermarket system should I look at that will power on and off remotely and be able to wirelessly broadcast the length of a 43' trailer plus truck?
I think I want one with its own display vs dash screen integration so I can just keep it on as a rear view camera when underway and not have to toggle displays when using the truck's head unit.
  • Butch50 wrote:
    I don't have a Jayco but our rear view camera is a Furrion Observation one and it works great but we are only 33' long trailer. Ours has been wired to operate with the clearance lights. So if I want to use the camera I just turn on my marker lights and boom there is the rear view.
    Same here except ours is 39 feet long. Keystone wired ours hot all the time from the factory and it burned out after 6 months. It was the Furrion backup so I got it replaced with the observation camera for a small charge, changed the power to feed from a marker light and it has worked great.
  • I don't have a Jayco but our rear view camera is a Furrion Observation one and it works great but we are only 33' long trailer. Ours has been wired to operate with the clearance lights. So if I want to use the camera I just turn on my marker lights and boom there is the rear view.
  • Scrounged around on YouTube with that part number and found a series of videos by a gent:
    https://youtu.be/CmgVCbBsPLY
    Not sure why he didn't just use a clearance light for power in the area of the camera, which would be switched.
    Then in a subsequent video he does some voltage drop calcs of clearance lights circuit based off the stationary battery voltage, instead of engine running alternator voltage (oops).
    Anyway, these videos seem to answer my questions.
    They have two models. The slow backup model and the fast observation. We have the latter and it works fine. They do need a good 12v power source. Chris
  • I did a Garmin and mounted a booster partway to the front of our 42' 5'er. The camera came with the 760 GPS from Costco.
  • Ours came with a Furrion wireless unit and have had no issues.
