- debraindiExplorerThe stereo system was replaced, Thanks for the information Cale. Its all good now I will add a few 1 by 2 s with plywood and get more storage, Thank you
- calewjohnsonExplorerDo you have a Kenwood amp up there? I have a 2007 Nitrous (the 23 ft). My cabinet above the radios has only an amp for the stereo system.
Cale - debraindiExplorerI looked on line and found the manual for wfco 45 amp converter and found that if the batters where connected in reverse polarity it blows the 2 30 amp, Sure enough one more problem solved. Im confused about the hot number 6 wire inside the rig above the radio. Could it be for a battery?
About Fifth Wheel Group
