bpounds
Oct 05, 2018Nomad
Imbriaco wrote:
My slides are hydraulic, with the motor and pump in the battery compartment up front. I assume that means I have NO wires running into slides meant to power the slide??
I don't think any of them have the slide drive inside the slide, and if they did, it would be 12vdc, not 120vac.
I assumed you meant the power running to receptacles in the slide is shorting, and that's why the GFCI in the kitchen is tripping. Same circuit.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
