Carl_n_Susan
Oct 05, 2018Nomad II
The 120V, 12V power and the propane line run under the slideout to a junction box at the rear of the slide on a Montana 3400. The junction box is a well known source of problems as it tend to leak. Remove the cover and check the 120V wiring there. Most likely the crimped connections have corroded and/or chafed causing the fault. The best solution is to solder the joints and seal them with heat shrink.
The Montana Owners Club (MOC) forum at www.montanaowners.com is a repository of all things Montana supported by over 15,000 owners. It is free to join and highly recommended.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
