bpounds
Oct 06, 2018Nomad
Roger10378 wrote:
Don't use Romex as it is not meant to flex constantly. That part of the wire should be a stranded wire. There is probably a junction box at each end of the flexible wire so I would replace the wire from box to box.
Agree with this. I also would not solder 120v connections. No good reason to, and that section of soldered wire becomes the same as solid wire, likely to break strands at the edge of the solder.
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 04, 2026
