- AllworthExplorer IILG!
- bartlettjExplorerI have an older LG compressor unit I bought 6 years ago, it works flawlessly. Note that compressor based dehumidifiers stop doing anything below about 40 degrees F so they don't freeze up. They draw air across a cold coil to condense out the water, then across a warm coil to heat the air back up to room temperature. Mine has a drip tank as well as a garden hose threaded drain connection. About all you have to do is dump the water and clean the air filter. Mine has a 2 gallon tank, and last weekend camping at Long Beach, WA, it pulled 1.5 gallons out of the air in 24 hours.
- SHExplorerFor winter storage I use a Davis Air Dryer in our 35ft 5th wheel and it keeps everything nice and dry. Has worked great for years!
air dryer by Steve Herrick, on Flickr - D_E_BishopExplorerDryzair is good and fast but it won't keep up with the weather on the Oregon and Washington Coasts nor NorCal coast either. We don't normally camp there is the fall or winter but if that changes, I'll get a good dehydrator and keep it going in the shower. I bought the dryzair at Freddy's, it is not the same outfitters it was when owned by the original family. Knogers has made it into a poor copy of WalMart such a shame for the locals.
- OasisbobExplorerMy unit is big and does not need to be. A smaller water collecting electric unit that will modify to drain outside is good. Home Depot has several. Read the reviews. Many are equipped with a hose connection. Yes, they will collect that much water. Set the humidity level at whatever you like and forget it.
- Mortimer_BrewstExplorer II
md_procouple wrote:
If your going to just use it for the "off" season, why not just by a couple of containers of "Damp Rid" you can get them at Home Depot / Lowes / Wallmart. W just get 1 of the large containers and 1 small one to put in our 5'er over the winter storage months, then just throw away and go. Good Luck and Happy Camping !!!
The best method for removing humidity is location dependent. Here in Illinois for example, Damp Rid is an excellent solution. I used a big bucket in our trailer every winter and never had any musty odors come springtime. Unfortunately, the humidity of the Pacific Northwest winter would overwhelm the biggest bucket. Hence the need for a dehumidifier.
What’s a mystery to me is how they deal with the gloomy days. I need my sunshine. - rhagfoExplorer III
Chuck .. wrote:
I am thinking it just might be better to have a electric dehumidifier in my 5th wheel this winter. I have a 33 foot DRV and looking for recommendations.
Well the question to chuck is, for storage or while in use?
When we stored ours between trips here in the PNW, used Eva-Dry, recharged about every two weeks at the house (two miles from storage). Now that we full time we have a GE 30 pint from Home Depot, we have it tucked under the Kitchen table. we have not had window condensation or wall condensation yet staying on the Oregon coast.
Damp Rid and Dryzair create a solution that if spilled on wood or carpet, creates a spot that will always be wet. - TenOCNomad
Damp Rid can only absorb about a pint of water. A real dehumidifier placed in the shower (so it can drain) will get rid of gallons of water each day. - md_procoupleExplorerIf your going to just use it for the "off" season, why not just by a couple of containers of "Damp Rid" you can get them at Home Depot / Lowes / Wallmart. W just get 1 of the large containers and 1 small one to put in our 5'er over the winter storage months, then just throw away and go. Good Luck and Happy Camping !!!
- n7bsnExplorerThe small cheap ones (EvaDry2200) can only lower the humidity in our rig to about 60%.
While the expensive ones (that use a compressor) can lower the humidity in our basement to 40%. We have it set to 1/2 way and it keeps the humidity around 50%
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
