filrupmark wrote:
azdryheat wrote:
I run LT truck tires with great success and without the cost of expensive G rated tires plus the associated rims to mount them on.
We run Bridgestone R-250 Lt tires and have no issues. Very happy with them.
I would have loved to have been able to run LT Load Range E but they aren't rated high enough for my trailer weight. I have 7,000 lbs axles so needed 3,500 lb per tire; most E's are 3,042 lbs only. I am running Sailun Load Range G tires with 4,080 lb capacity and so far they are fantastic. On larger tandem axle trailers you are pretty much forced to go with a G or even an H rated tire in some cases.
