GoPackGo
Nov 23, 2013Explorer
Heating the Rig in Winter
I have a 2014 Bighorn 5th wheel that I will be moving into fulltime within 30 days. I will be staying in Florida this winter, but not sure if it will be the northern or southern part. The rig has ducted AC and the factory installed furnace that is also connected to the ductwork.
I also have the Yeti package, which I believe adds insulation, heating pads to the freshwater, grey and black tanks, and also heat tape to the water lines.
I understand the OEM propane furnaces use lots of gas so I want to reduce usage. I will be getting a free-standing electric heater (possibly an oil filled one or a ceramic heater) and using the electric heater as much as possible.
As an example, at night I guess I would set the electric heater at something like 60 and the OEM furnace at something like 55 ???
Here's my concern - If I'm mostly using the electric heater, then there is no heat being sent to heat the areas that contain the tanks and water lines that would normally be heated by the furnace ductwork. So I was thinking that I could set the AC to 'fan-only' and that way heated air from the living areas of the coach would be circulated to those areas. Has anyone tried this ? Does 'fan-only' use the same ductwork as is used by the OEM furnace ?
I know the Yeti option is supposed to solve at least some of the cold weather concerns but I'm not sure if ALL lines are heated or just the main incoming line.
* One side question - Since the Yeti package adds a heating pad underneath the freshwater tank, does that mean I need to keep some amount of water in it to avoid the tank being melted by the heater ?
I apologize to everyone up north for using the words 'winter' and 'Florida' in the same sentence. I realize that's quite laughable. :B
Thanks in advance.
Tim
Thanks in advance.
Tim
