Klueck
Mar 06, 2017Explorer
Fulltimer50 wrote:
I think if you put the try on top of the carpet, you may find the feet are soon breaking trough the tray do to movement and weight. I would either remove the carpet or if concerned about resale, put a piece of plywood on top of the carpet and the tray on top of that(since you all ready have the tray.
What location would prevent you from using a vented model?
I think you're right about putting the try on top of the carpet. We will either remove the carpet or put plywood on top.
The reason we went with the ventless is because the plumbing is not by an outside wall and from what we had read, that might be an issue to run the dryer vent an extra two feet. We have a vented one in our current motorhome and it works fine. We decided we could make it work with the ventless....although it was NOT our first choice.
Thanks
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
