jackbuck's avatar
jackbuck
Internet use
How do you connect to the internet without using the free wifi in campgrounds or having satellite?
Are libraries safe?
Please help!
  • Dick_B wrote:
    We go thru our Smart Phone with Verizon but you can run out of minutes if you use it for more than a few minutes per day.
    Data does NOT take up your talk minutes. Data is data, whether it is being used by your phone or a hot spot it is still data.
    Now if your implying that using your phone as a hot spot runs the battety down, then yes, that can be true. But thats what they make charge cords for.
  • Verizon has the Jetpack module and ATT has the Sierra module. I have both and both work about the same. ATT seems a little cheaper. That may be because I also have a ATT cell phone. Both of those modules can have passwords that are up to about 65 characters long. We also use these kodules for our home internet service.
  • I, too, use a Verizon Mifi... data only hotspot. It connects by cellular.
    As for your library question... depends on your definition of "safe". Anytime you share a network with others prior to the router connection to the Internet, you are less "safe" than if you have your own connection. Personally, I NEVER do banking (for example) on anything less than my own (individual) connection.
  • We go thru our Smart Phone with Verizon but you can run out of minutes (sorry, meant data limit) if you use it for more than a few minutes per day. Streaming videos is a killer.
  • We use a Verizon jet pack (mifi). Perfect. We have the 20mb package at $100/month. Use it at home as well
