GoPackGo
Nov 04, 2016Explorer
I have a washer/dryer in my rig and love it. Would not be without it. I do realize you may have a space problem.
Propane vs electric heat. First you need to know if electric is included in your campsite rent. It usually is if for daily, but usually is NOT if signing up for a month at a time. Then you will need to know what the KWH rate is that you will be charged. Then you need to know what will be charged for a gallon of propane. THEN, you can compare the cost and decide which is cheaper. There is a nice comparison formula floating around that allows you to input costs for electric and propane, then determine which is cheaper to use. You should also understand that many propane furnaces are ducted into the underbelly so your water tanks and lines get some heat to keep them from freezing in cold weather. Using an electric heater set up in the living room may not route any heat to the tanks and lines, which could cause a freeze problem.
On edit - forgot to talk about mail.
You are already in Texas and I ASSUME that will be your domicile state. If so, you have a ready made solution - contact ESCAPEES.com. They are headquartered in Livingston, Tx. Florida is my domicile and I use a different company - ST Brendan's Isle, which is also very good. Full disclosure - I belong to Escapees.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
