rodwha's avatar
rodwha
LPG Cylinder Swap
I've seen how some LPG tanks/cylinders are measured by lbs and some by gals so I wondered if there was some sort of typo or maybe I just misunderstood as I thought all cylinders were measured by lbs so I looked at our outdoor grill and noticed a 15 lb cylinder and not a 20.
I have assumed these (BBQ grill) were standard size and that when it came time to swap cylinders for an RV you would do so at the grocery store. So where do you swap out 20 and 30 lb cylinders?
Also how does the weight to volume compare? How many gals does a 20 lb cylinder hold?
  • I bought the tanks and have them filled, why would you swap a new tank with another one? I bet the "grocery store" you swap it with doesn't give you a full tank.
