rodwha wrote:
eith the proper sized inverter, running an A/C could be done using a generator to recharge during the day. It seems a bank of 4 (unknown output batteries) aren't up to the task for long enough.
No, 4 batteries won't be enough.
I am one of the few on here who runs a/c on batteries - but only occasionally. I have 8- 80a AGMs, a 4kw inverter, 835w solar. It's a 48v system. Why 48v? Because when I tried running air at 12 or even 24v, things started heating up. Cables, connections, batteries. Yes, everything was sized properly, but the high amperage draw eventually made heat. 48v seems to work fine.
I can run my air for about an hour before the batteries start to sag, even at full solar.
