BruceMc
Sep 20, 2018Explorer III
Ralph Cramden wrote:BruceMc wrote:
It seems today's generations are litterbugs, not just in the hidden spaces in our motorhomes, but in life in general.
If you take a few tours of RV factories you would find it has nothing to do with todays generation. It has to do with todays management and more with todays piecework method of compensation. All they get is a quick broom sweep, then theyre pushed out the door to the storage and shipping lots. Doing the final clean is on the dealer with most brands and the dealer is not going to spend much time if any pulling out drawers and removing cabinet baffles. You think their is debris there? Try looking in the space above the underliner, or in the black tank. When they uses a hole saw to pop a 3" hole in the top of an abs tank, where do you think the slug goes? Usually a gift to later jam up yhe blade valve.
Agree. It's a hot market right now, so management is pushing hard to get as many units out of the door as possible. They clear only what is visible, the rest is out of sight, out of mind.
I, too, had a problem with one of my wastewater slide valves, and when I took it apart, I found a piece of vinyl that looked a bit like flooring, yet it didn't match my flooring.
When I worked at Terry Trailers in LaGrande, Oregon in the late 70's, we had cleaning crews at various points along the assembly, and particularly at the final inspection. Terry exists today, but only as a niche builder of retro trailers.
38,782 PostsLatest Activity: Sep 10, 2026
