staltydog
Sep 11, 2017Explorer
03 HR Ambassador Sudden Loud Air Leak Driver Side
We have recently built a Storage Building on a level concrete pad. In the past the area was not level and I parked with the air parking brake on. Now that it is level I used wheel chocks and parking brake off. However, I went to start the coach after about 3 weeks parked I noticed the parking brake control button was popped up in the On position. Once started the air tanks began to fill and at about 80 PSI I heard a loud air leak noise directly under the driver side. I did a quick look under and could not find an "obvious" leak. Also, the Brake light would never go out - although the brake did not seem to be on as I could put the coach in gear and no noticeable brake seemed on. Is there a valve somewhere I should check? Any advice on this Roadmaster chassis?
