Clay_L
Jun 15, 2015Explorer
As a side issue:
Please note that the 2003 chassis (W20 and W22) had a 2 inch front stabilizer shaft. Often called an anti sway bar. In September of 2003 WH changed to a 2.5 inch bar.
If your chassis has the 2 inch bar I would strongly recommend that you have the 2.5 inch bar installed. I did and it made a huge improvement in roll or side to side sway.
This is from an email I got from WH in 2005:
"The part number for the Front Stabilizer Bar with Brackets is: W0005643.
This bar was found to have an advantage over the original 2" bar, and was
put into regular production on 9/2/2003.
The installation is very straightforward. Remove 4 retaining nuts while
supporting bar, remove bar, hold new bar in position, reinstall 4 retaining
nuts, and torque to specification. This procedure is NOT meant to replace
the service manual, but is a generalized procedure.
The upgraded stabilizer bar has been shown to provide the following
benefits:
1. Reduced Body Roll when cornering.
2. Reduced "rocking" when passed by or passing large vehicles.
3. Reduced "rocking" when traversing bumps on an angle."
The installation procedure is below- I did not raise the coach, just crawled under it:
Stabilizer Shaft Replacement (Front) (W20/W22)
Removal Procedure
1. Raise the vehicle on a hoist
2. Remove the nuts and washers from the stabilizer shaft clamp and the right front leaf spring.
3. Remove the nuts and washers from the stabilizer shaft clamp and the left front leaf spring, and remove the stabilizer shaft from the vehicle.
4. Remove the clamps from the stabilizer shaft.
5. Remove the insulators from the stabilizer shaft.
Installation Procedure
1. Install the insulators to the stabilizer shaft.
2. Install the clamps to the stabilizer shaft.
Notice: Refer to Fastener Notice in Cautions and Notices in the WCC Service Manual.
3. Install the washers and nuts to the stabilizer shaft clamp and the left front leaf spring.
4. Install the washers and nuts to the stabilizer shaft clamp and the right front leaf spring.
Tighten the stabilizer shaft clamp nuts to
373 N·m (275 lb ft).
5. Lower the vehicle.
benefits:
Removal Procedure
