garymunson
Sep 21, 2014Explorer
04 Fleetwood Flair ignition switch
Anyone else had problems with a Fleetwood ignition switch? My Workhorse chassis Flair seems to be different than the ones discussed in the posts I've searched. My column, for want of a better term, looks 'European' with a large plastic shroud around it. I had hoped for the one with the GM rectangular switch on the column actuated by a rod from the key switch. This looks different.I'm not wanting to pull the steering wheel until I can find some info about it. I'm thinking the switch is underneath the wheel hidden by the shroud which needs the wheel off to remove.
