jchonroad's avatar
jchonroad
05 Winnebago / Workhorse W22 - no left brake light
Have lost the left brake light on my Winnebago Voyage on a Workhorse chassis. I have replaced the bulb, to no avail. I've discovered that I don't have the left brake light on the toad, either, which leads me to a blown fuse or bad relay. Problem is, I can't seem to find either the fuse or relay. Does anyone no where they are? Thanks in advance.
John
  • You may find the problem lies in the turn signal switch. I had that problem and that fixed it. Chances are this is the correct part (but double check).
    https://www.ebay.com/itm/Front-New-Turn-Signal-Switch-Chevy-Olds-Yukon-Suburban-Avalanche-Silverado-1500/310725158206?epid=21015697829&hash=item4858a9a53e:g:KmIAAOSwr5ZalnQk
  • You won't have a fuse or relay for just one turn signal. Pull the tail light assembly out and see if you have a loose ground or hot wire.
