racerguy's avatar
racerguy
07 Endeavor Headlight Problem
The headlights on my 2007 Holiday Rambler Endeavor completely died yesterday.
No high or low beams. I've spent 4-5 hours checking and testing all the obvious suspect items. Bulbs are good, no blown fuses or bad relays, headlight switch OK, dimmer switch OK, etc.
Is there a special relay, controller or circuit breaker somewhere other than in the front run bay?
  • FIXED - Thanks to YC1 sending me a headlight wiring diagram on the "other" forum!
  • Thanks Don. I've been working with the VIP troubleshooting guide all day. Still no resolution. Everything I test appears to be good.
    Tomorrow I hope to get the module dismounted and accessible to do the diagnostics more accurately. It's not easy to get at the terminals with it bolted up under the dash.
  • If you have a SmartWheel, the lights run through it (ICC switches). You can download info from the SmartWheel website on trouble shooting.
