Blackdiamond
Apr 24, 2014Explorer
tinkerer wrote:
We have the same coach and had problems with the electronic jacks,they have an upgrade seal kit which helps but have learned that cycling them at least every 30 days solved a lot of problems. I am amazed how rv mechanic's like to replace the jack motor when the problem is just a corroded jack brake.Also there was a recall on the battery cables that could rub threw where they leave the compartment. I also had to replace a couple of battery cable ends. You will love the full slide. Good luck!
On mine there was a shaft that was shattered in the motor assembly on both rear jacks, happened within months of each other.
38,706 PostsLatest Activity: Dec 02, 2016
