Loren Ross wrote:
In my 07 32vs, there was a 17" flat screen tube TV.  It was strapped in from the sides with black fabric straps.  Nothing was glued, it was just held in place with the straps.  There was a metal buckle in the middle on the top rear of the TV.
I wish mine was the CRT as it would be easy to remove.....whereas this LCD (which was an option) wiggles around on the plastic pedestal like a bobble head doll.  I tried using dental floss to get under it and pull back and forth, cutting through the tape however it broke which does lead me to believe there are in fact a couple of hidden screws in between the shelf it sits on and the veneer underside.
That said, the veneer and front trim piece are fastened by an air stapler with long legs and I'm reluctant to start ripping material out of that area as it will create a headache I don't want.
The front TV wasn't bad but this one is a hrmmmm.....problem?
